Sign in to follow this
wolfrem68
stick framing
Perspective (or Orthographic) Framing Overview?
framing over view. I want to be able to just see the framing members of the drawing. I have looked at both perspectives perspective and orthographic but do not see the view of only framing.
thanks.
I finally found the right view. Orthographic view. Thanks again for the help.
Just to clarify, all you really need to do is switch to a layer set that has the framing turned on and everything else turned off.  We ship with a default layer set called "3D Framing Layer Set" that will do this for you.  The Orthographic Framing Overview and Perspective Framing Overview cameras just use this layer set by default but you can use this layer set in any camera view.
Also, you need to be sure and build your framing before you can see it.
    27870
    Resolvetheissue
    Resolvetheissue
