display differences between views
RFCONINC
Vector views use the Pattern that is defined in the Material Definition while standard render camera views use the Texture properties that have been defined in the Material Definition.  Since you have X11 you can now generate a Pattern from the Texture but unfortunately it does not work the other way yet.  Bottom line is you need a herringbone Texture file.
