Frameless cabinet Box thickness
Rossalaki
How can I change the box material thickness of a kitchen cabinet?
The default seems to be 3/4. When I make an open face (no doors) frameless cabinet in chief. the thickness of the box is 3/4". How can I change it to 5/8" for example?
Thank you!
OK, did this over coffee. Cabinet set to 3/4 deep, used custom cabinet doors (one for top/bottom and 1 for sides) to make the box. The sizing on the door symbols has to be locked in two of the dimensions the 5/8 and the cabinet box depth. Open included symbols to get an idea.
I wouldn't normally bother with this, if I needed to show the 5/8 thickness a CAD detail would usually suffice but just in case. BTW there is a CAD detail from view taken which was pasted back (and hold position) into the elevation view so that the box could be dimensioned.
58 side cab.plan
