tds_cc Posted March 1, 2019 Share Posted March 1, 2019 Hi all. There is a rogue toilet in a plan I am working on - my coworker and I can't figure out how to select to delete it. It's unselectable! Has anyone else ever had this problem? (By the way, I tried to upload the plan here, but it is way too big for what they will allow, even after I compress it.) Thanks! Link to comment Share on other sites More sharing options...
tds_cc Posted March 1, 2019 Author Share Posted March 1, 2019 1 minute ago, solver said: Can you select other fixtures? Is the Fixtures layer locked? I can select other fixtures. The fixture layer is not locked. Link to comment Share on other sites More sharing options...
tds_cc Posted March 1, 2019 Author Share Posted March 1, 2019 3 minutes ago, solver said: Have you tried using Edit Area? That worked!! Thank you so much! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 1, 2019 Share Posted March 1, 2019 Are you using a reference set? if you are then you must change anything referenced in that layerset. Link to comment Share on other sites More sharing options...
