Fun2Learn Posted March 1, 2019 Share Posted March 1, 2019 HI everyone. I prefer the lighting as shown in the default views. However, when I add a single lamp or light fixture, the lighting switches to only the light as would be coming from the light fixtures. Is there a way to override that and just keep the general default light source (you know, that "etheral" undefined bright light coming from the ceiling, LOL! When I am just doing a quick design, I don't want to worry about adding enough lights and fixtures at this point. The rooms usually looks very dark with only one or two lamps in it!) thanks! Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted March 1, 2019 Share Posted March 1, 2019 No, you have no control over the default light source. The moment you place a light fixture in your plan CA eliminates the default light source, even if you added light fixtures are all turned off. Have you tried using the 3D view default settings to adjust the interior ambient? You can also add your own 3D light as a substitute for the lost CA one, at least with this you can adjust it to your liking. One thing you can do is open the light fixtures Symbol DBX, under options uncheck "Light", now CA will not see it as a light fixture. If you do this for all of your light fixtures then CA will put the general default light source back in the plan. Link to comment Share on other sites More sharing options...
