BFogarty Posted February 18, 2019 Share Posted February 18, 2019 Hi, Can somebody take a look at the door thresholds in the front breezeway entry and the main entry (2nd door inside vestibule), what the heck is up with these things??? On top of that, what's up with the little apron under the sill? Looks foolish, and you cannot modify it....and if you uncheck it, then it picture frames the door.....who does that...lol My main concern is the threshold with the gap in it, the other stuff is just venting Thanks! BTW, this plan is in X11 23 Cedar St As-Built X11.plan Link to comment Share on other sites More sharing options...
BFogarty Posted February 18, 2019 Author Share Posted February 18, 2019 26 minutes ago, solver said: Floor to Bottom is > 0 on thoes 2 doors. The only result I'm getting by changing that number is the door is going up/down Link to comment Share on other sites More sharing options...
BFogarty Posted February 18, 2019 Author Share Posted February 18, 2019 11 minutes ago, solver said: I changed the small room in front of the solid door to a porch so Chief would think the door was an exterior one. Gotcha....Thank you Sir! Link to comment Share on other sites More sharing options...
Kbird1 Posted February 18, 2019 Share Posted February 18, 2019 1 hour ago, BFogarty said: The only result I'm getting by changing that number is the door is going up/down Yes Chief Auto adds a Apron under doors if they are not at 0" off the Floor.... 1 Link to comment Share on other sites More sharing options...
