How do you re-run the Migration tool?
Meltdown00
As I was installing the X11 Beta, the program froze at the Migrate dialog and now it goes straight into the startup screen and I can't re-run it. Even after uninstalling and reinstalling. Is there a registry key I can edit to force X11 to think its a new install or something?
Renaming or Deleting the .ini file will do it ...it is not deleted on an uninstall , a good thing I guess in most cases as it also reinstates your Preferences etc on a reinstall. I suggest making a backup copy ( or rename it ) before deleting just in case , as you can see below in my pic I have several extra folders with backups. Once deleted I think the Repair Option in Control Panel>Programs or the Apps Settings will get it to run the migration again. *** confirmed working in post below ***
It is normally in the User's AppData>Roaming Folder>Chief Architect Inc , if you have more than one version of Chief installed there will be multiple Files
eg.   C:\Users\YOUR_USERNAME\AppData\Roaming\Chief Architect Inc
*** updated  : there is also a setting in the .ini file ..............             Migrate%20User%20Settings=false
it maybe worth trying setting it   =True    to see if it triggers a migrate when X11 next starts
8 hours ago, Kbird1 said:
Deleting the .ini file will do it ...it is not deleted on an uninstall , a good thing I guess in most cases as it also reinstates your Preferences etc on a reinstall. I suggest making a backup copy before deleting just in case , as you can see below in my pic I have several extra folders with backups. Once deleted I think the Repair Option in Control panel or the Apps Settings will get it to run the migration again.
It is normally in the User's AppData>Roaming Folder>Chief Architect Inc , if you have more than one version installed there will be multiple Files
Aye, that's the ticket laddie.
Much thanks!
