How to insert cabinet door into plan?
dskogg
Normally, a message will come up letting you know that a cabinet door is intended to be placed into a cabinet.  The message will then ask you if you would like to place it into the plan as a fixture.  If you are not seeing this message, it may be because you saw it once, checked "remember my choice" and then clicked no.  You may want to reset your message boxes in preferences to get this message back.
Thanks Dermot, i thought that remember my choice only worked in the current session, good to know.
Worked now.
Cheers.
