toller65 Posted February 3, 2019 Share Posted February 3, 2019 Newbie here - using Home Designer Suite 2015. Seeking help from someone to make some modifications to the attached plan. I need to make the knee wall hieght on the interior finished surface of the upstairs rooms 24" from floor to ceiling plane. The roof pitch is correct at 10:12. The plan in general is decent, but htere are probably a bunch of details that could be cleaned up. Happy to discuss fees. Thanks 01Feb2019_Project.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted February 3, 2019 Share Posted February 3, 2019 17 minutes ago, toller65 said: Newbie here - using Home Designer Suite 2015. Seeking help from someone to make some modifications to the attached plan. I need to make the knee wall hieght on the interior finished surface of the upstairs rooms 24" from floor to ceiling plane. The roof pitch is correct at 10:12. The plan in general is decent, but htere are probably a bunch of details that could be cleaned up. Happy to discuss fees. Thanks 01Feb2019_Project.plan did you try these Tutorials? https://www.chiefarchitect.com/support/article/KB-00772/building-a-cape-cod-roof-by-adjusting-ceiling-heights.html https://www.chiefarchitect.com/support/article/KB-00653/building-a-cape-cod-roof-that-bears-on-the-1st-floor-walls.html https://www.chiefarchitect.com/support/article/KB-00648/creating-an-automatic-dormer.html The HD versions of above.... https://www.homedesignersoftware.com/support/article/KB-00358/automatically-building-a-one-and-a-half-story-roof.html https://www.homedesignersoftware.com/support/article/KB-00367/drawing-a-shed-dormer-manually.html If you still need help after those PM me..... Link to comment Share on other sites More sharing options...
Mark3D Posted February 3, 2019 Share Posted February 3, 2019 i had a play with your file it might be enough to get you going if you need other change i can do it as i have chief x6 install on old laptop as that should be compatible with version 2015 designer 01Feb2019_Project mark alter.plan Link to comment Share on other sites More sharing options...
toller65 Posted February 3, 2019 Author Share Posted February 3, 2019 Mark3D - thank you so much for your edits, I think I now have what I need ot be able to place my plumbing fixtures on the 2nd floor!!! Have a great day! Link to comment Share on other sites More sharing options...
