Stair Enclosure
Aamir77
Aamir77
Here is a wall that has the features that you are looking for.
1 draw stairs and floor above
2 add stairs and stairwell (auto stairwell can be used to cut the hole in the floor above.
3 draw a wall on the lower floor next to the stairs
4 in section, drag the bottom of the wall up to lowest elevation that you need
5 drag up the high-end corner to match the slope
6 open the wall database interface window and change the wall type to No Locate and No Room Definition.
See attached plan file.
Upper Stair Wall.plan
