ACADuser Posted January 15, 2019 Share Posted January 15, 2019 So I have a front elevation & almost finished annotating it and realize my leader heads are too small. So how can I group select the leaders & change the arrow size in mass? I would resort to the Object Eye Dropper but it is useless as it will not transfer arrow size. Any suggestion for group select? Link to comment Share on other sites More sharing options...
Dermot Posted January 15, 2019 Share Posted January 15, 2019 Select the Text Line with Arrow tool. Use the marquee select method to select all your leaders. Use the Open Object tool. Modify the properties as needed. Link to comment Share on other sites More sharing options...
ACADuser Posted January 15, 2019 Author Share Posted January 15, 2019 Thanks that worked a treat. I guess before I had used the Leader Line tool and did not get the results I needed. Link to comment Share on other sites More sharing options...
