Wall Fill
QualicoreHomes
Hello,
I was wondering if it is possible to have the interior walls with two fills.  For example my interior walls are automatically filled with the yellow standard color.  I want some of the walls to be 2x6 for the plumbing pipes but then they change to the standard blue color for the 2x6 wall, but I want to keep all the interior walls the same color fill.  I added a wall type called plumbing wall and made the fill also the yellow standard color but now was hoping I could also add an angle hatch to it so it shows that it is a different wall but then in a more subtle way.  Is this a possibility? Or would you suggest to go away from the color fill completely and only use hatching to differentiate between walls?
