winterdd Posted December 31, 2018 Share Posted December 31, 2018 hello everyone, i am new to chief and finding it very easy to learn. i have had no problems figuring out object colors. however, can anyone tell me how to change entryway colors. under materials it doesn't give me the option like everything else does. just the trim and casing colors. i need it burnt red to match the home. see below....thanks Link to comment Share on other sites More sharing options...
winterdd Posted December 31, 2018 Author Share Posted December 31, 2018 library Link to comment Share on other sites More sharing options...
winterdd Posted December 31, 2018 Author Share Posted December 31, 2018 and i assume the signature is recommended so others can tell what version i'm on and what computer setup i have? Link to comment Share on other sites More sharing options...
javatom Posted December 31, 2018 Share Posted December 31, 2018 If it is a material you can see on your screen, you could use the material painter tools. Click on the one you want to capture and then click on the item you want to paint. It is a great tool but don't use it to change siding types (do that under wall definitions). Link to comment Share on other sites More sharing options...
winterdd Posted December 31, 2018 Author Share Posted December 31, 2018 great info guys, thanks! i will add to my sig. chief x10 Link to comment Share on other sites More sharing options...
winterdd Posted December 31, 2018 Author Share Posted December 31, 2018 eyedropper tool worked so easy........quick and fast. i tabbed on the mulled unit and it worked too. Link to comment Share on other sites More sharing options...
