JaycoBuilders Posted December 20, 2018 Share Posted December 20, 2018 I need to create a wall that slopes outward 24" from bottom to top. Anyone done this before? Link to comment Share on other sites More sharing options...
glennw Posted December 20, 2018 Share Posted December 20, 2018 Do you need windows and doors in the wall? Link to comment Share on other sites More sharing options...
javatom Posted December 21, 2018 Share Posted December 21, 2018 A wall can not do it. You can use a molding but as Glenn pointed out, a window will cause some problems. Link to comment Share on other sites More sharing options...
DBestDesigns Posted February 1, 2019 Share Posted February 1, 2019 I have the same question. I designed this catamaran yacht years ago using CA and have been able to create everything but the reverse walls. Here is a picture of the project done on another program. Link to comment Share on other sites More sharing options...
glennw Posted February 1, 2019 Share Posted February 1, 2019 The simple answer is - don't use walls. It looks like you don't nee traditional walls anyway. Depending on your exact needs, there are other tools such as solids that you can manipulate. Link to comment Share on other sites More sharing options...
