ChiefuserMathews
Garage Floor Opening
Hello, I am cutting the garage floor to make a below grade entrance to a basement with a concrete stair. How come, when I make the floor opening for the stair, it shows wood beam material around the opening? I have attached an image for reference
Have you tried to change the material on your railing wall to concrete?
The default railing wall is a stud wall, so I'm guessing you are seeing artifacts from that.
Try changing to a solid concrete wall set as a railing.
Why would there be any wood joist at the perimeter of the garage floor opening? Garage floor is on grade and with concrete slab. why would the program add the wood structure to it? any reasons?
    27611
    ChiefAKBuilder
    ChiefAKBuilder
