how to rotate 3d object in elevation?
beejal1
The only way, within Chief Premier that I know of is by way of the "Edi 3D Symbol Dialog" using the "Orientation" settings (X,Y, Z Axis) settings. Otherwise you would have to export the object as a symbol and then using the above tool, reorient that symbol to the desired new location per instance.
