wncbw7 Posted September 23, 2018 Share Posted September 23, 2018 When using the orbit tool to adjust the angle of view for a perspective view I like to keep the vertical walls plumb and avoid angled verticals. Sometimes it is a little tedious to get the verticals perfectly straight. Is there a hot key I can press while orbiting that would force the vertical walls to be plumb? Thanks in advance for your help. Link to comment Share on other sites More sharing options...
glennw Posted September 23, 2018 Share Posted September 23, 2018 First off, to keep the wall corners vertical, you need to set the Tilt Angle to zero. You then have to keep it at zero whilst you orbit the camera. Keyboard Orbit Camera (with left and right arrow keys), Orbit Camera Left and Orbit Camera Right will do that. You can also use camera movements like Mouse Dolly, Mouse Pan, etc. Or you can move the camera in plan view with the mouse or the keyboard arrows. Link to comment Share on other sites More sharing options...
wncbw7 Posted September 25, 2018 Author Share Posted September 25, 2018 GlennW, thanks for the reply. "Tilt Angle" that was what I was looking for. Link to comment Share on other sites More sharing options...
