Corner angled steps, stairs
Designer100
I need a ushaped stair with 9 risers at long wall side and 2 corner steps at each corner. not landing there.
Can anyone help with this? O have never designed one of this? I am doing a remodeling on the 3rd and 4th floor of townhouse. Existing plan in background. Just drawing outside walls and stair on inside of 1st and 2nd floor.
any help appreciated.
townhouse.plan
Hi Newell see if this is what you were looking for you don't have a second floor drawn so I am not sure where these steps will be going, what I did was deleted all of your stairs except the first set then made a box the way I want the first step to be and converted into a landing, did the same thing with the second step but had to raise it up 7 5/8" higher then the bottom height of the first landing once I did that I drew another set of steps up from that landing starting against the upper most landing
townhouse STAIRS.plan
