Replace Color Tool ?
jjifmeyer
I am familiar with using colors and paint tools and droppers as well as setting up custom color pallets, but I can’t seem to find a “replace color” tool.
Does one exist in CA?
So I can simply and quickly replace all of one color with another in one click.
Let’s say replace the exterior siding color from red to blue in one click instead of each section /wall at a time.
While testing exterior colors
(Something similar to Adobe Photoshop or Illustrator)
or is the only way in “Default settings” ?
Thanks
One of the most valuable help resources you have at your fingertips aside from the built-in "Help Files or F! Key" is your built-in Reference Manual found under your "Help Menu" which is searchable by topic. Next is the Knowledge Base of help articles resident as part of the Chief Architect Website. I found this article there in about 10 seconds this evening to help you with: https://www.chiefarchitect.com/support/article/KB-00793/using-the-different-material-painter-modes.html. this article explains the "Modes" available for use of the "Materials Eye Dropper", once you understand and practice using those modes, I believe will "answer" your posed question.
