Deleting cut points
shingabiss
Yes.
For a roof or closed polyline, grab the break point and drag it along and snap to a corner or break point.
Or you can use the Intersect/join 2 Lines tool.
Walls are a little different, you will need to manually delete any unwanted wall sections.
Or, if it is a colinear wall you can use the drag/snap method.
