reflecting issue in PBR
prorefinish
Hi guys,
I have an issue with PBR camera view. As you can see on the attached pic the reflection of the textures are missing in PBR. I know I do something wrong just can not figure out what is that.
My second issue when I rendering this plan with this settings the result is dark and shady (untitled 5 renderelt 02.jpg)
Thank you!
Any advice are welcome!
5 hours ago, Cheryl_C_Crane said:
I made myself a tiny PBR toor bar
OK there is the TIP for this Thread  since it should really be over in the Q&A Forum :)
It is always best to post the Plan file in cases like this , there are just too many varibles , which leads to too much guessing as to the cause...
Also ...No Signature = No secret Handshake for you  :):):)  (J.J.)
It's good to have your Forum Signature filled in, especially with the Software Version, and of course a real Name is nice too :) ..............
See mine below in Blue for how to do that.
If you don't see my Signature then you have them turned off for the Forum so you need to Toggle it on by going to the Upper RH Corner of this Forum Window and Clicking on your Username and making sure Signature are enabled (green) and then Add your Own Sig. too :
UserName> Account > Signatures
If there are no Windows and Doors to allow Light in you may need to add some raking light by adding a 3D light down near the Floor ?....
No Sunlight = no reflections or subdued Reflections in PBR
Okay found Graham's post from last week , try these Settings perhaps....
Lots of good info in the Lets PBR Thread too.... but this is my post in it with the basic setup , have 100 automatic lights is important
https://chieftalk.chiefarchitect.com/topic/16912-lets-pbr/?do=findComment&comment=142683
Good morning,
thank you all your help and tips. Finally I figured out I think. I played with sun lm and angle and materials. What I think some materials can not reflect as I except so I changed some of those. (but maybe I am wrong)
So for this attached plan: Light settings max 20, spot light with 85Lm, sun int: 1200, tilt angle: -32.3, direction angle: 80.4, and PBR.
1 hour ago, prorefinish said:
Good morning,
Attached picture, not plan?
This doesn't appear to be the kitchen you posted above yesterday......  the Windows should help greatly in PBR with the lighting.....
    30184
    F16Squeaky
    F16Squeaky
  • Similar Content
    • By EvanDesign
      I'm sort of new to CA and I've noticed that every time I go to set up my PBR it takes me FOREVER to get it looking good. This time however it has taken me forever to make it look good and I still cannot figure out how to fix this.
      Can someone help me figure out what I'm doing wrong, I find PBR to be so challenging.
    • By Renerabbitt
      X-13 RTRT, A breakdown from another forum in response to growing frustrations with RTRT.  (Items that are specific and searchable terms in CA have capitalized first letters)   There is nothing "wrong" with the new Astral PBR RTRT option. Better understanding of a modern rendering engine may help alleviate some issues. If you are feeling overwhelmed by this info you can always uncheck the option for the RTRT in your Rendering Techniques Tool. Feel free to contact me for support or advanced training. • In RTRT a low sample rate is used in live camera views. • For exported presentations images similar to a CPU-based RT, set your Maximum Export Samples as low as needed to eliminate fireflies and light leaks. The higher the sample rate in RTRT Rendering Techniques, the better the image(up to a point where benefits are negligible). This only applies to the Export Image Tool. • A sample rate in basic terms is the number of samples from a camera of a given Objects Material ID as it applies to the geometry of an object, including colors, lighting, shadows etc. The more times something is sampled the less aliasing there exists in a final image. • The more light exists in the scene the easier it is to Sample. • You must supply ample light in adjacent rooms for the RTRT engine to properly process and "trace" your scene. Devoid of light, your exterior will be overly exposed, your interior may be underexposed, and you may have fireflies or light leaks. • Ensure that your active Light Set is on and illuminating your scene, which is accessed a number of ways, one being the Edit Active View tool, in the Camera Panel, under the Lighting Section. • With ample lights, an interior scene Rendering Technique Options might have an exposure from .15-.35, a Maximum Sample Rate of 500-1500, a Brightness between -10 to 0, a Backdrop intensity between 100-1000. This is not and never will be a universal setting, each scene needs adjustment according to the amount of light available to that scene. • If your scene is underexposed you may need to adjust your lighting including the lumens of your light fixtures. • Sun settings will do very little to help overexposure, underexposure, light leaks or any other trace related problems. This is the nature of a tracing engine. • Live view will always be of lesser quality than an exported image using the Export Tool(because of the option to change the sample rate.) • Typical problem causing issues: Caustics, Lights near transparent or translucent surfaces, lights of high Lumen values in one room juxtapose to lights of low lumens in an adjacent room. High resolution bump/roughness/normals maps in materials. These issues all cause difficult scenarios for attenuation and aliasing.    Some of the fixtures being used are not optimized for this new engine. Consider changing the material properties of any glass that is in close proximity to a light source. Changing the glass material of a light fixture that is turned on in a RTRT camera from Transparent class to General Material with high Transparency can yield much more predictable results. Same goes for situations when inside cabinet lights do not show up in RTRT behind Transparent Class windowed cabinet doors.   There is a lot more to this, you can have some success with this info, but barely scratches the surface. For some incredibly good generalized rendering info, read the Thea Render Manual(free online) It has some fantastic info in it that applies to all rendering engines. The following images are a RTRT with zero lights(screen clipped), an RTRT with lots of lights and same settings(screen clipped), and an RTRT export of the same scene The last image has the backdrop turned up since the sun direction is not illuminating the backdrop. Backdrop setting of 1000.
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11 and X-12.
      These items are for X-11 and X-12 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL   RABS INTEGRATED SINK - DL NEW!!! 03/26/2020
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL CAFE APPLIANCES, PAINTABLE(CORRECTED) - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4 RECESSED NC HALO 4 INCH LED WITH HOUSING - DL NEW!! 03-22-20
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     FIREPLACE STACK TOOLS - DL ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL    BATH SURROUND TOOLS
      VIDEOS:
      YouTube Channel
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests 03-30-2020-6:49PM: Deleted Video Links and added link to YouTube Channel   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By IvanCyr
      Showcasing a space can sometimes best be accomplished by showcasing the entire area within an integrated 360 Tour.  Video is great for clips, generating interest, investment, and capital campaigns but it drives a user on a set path on a set time frame.  Try a 360 Tour!  Your users can take all the time they need and really get a feel of a space.  Please see one posted at the link below:
      360 Tour
      Tours can be generated easily and quickly.  All we need from you is the 2D or 3D floor plan(s) you wish to use, and the spherical images you wish to upload.  A company logo, text, and even video can be set into the tour as well.  Tours run off our own server and will be active for 18 months upon payment.  Very competitive pricing and updates are fast and easy providing the images are resent using the same file names.
      For more information email ivancyr@inteck3d.com.
      Ivan Cyr
    • By hamedDesighn
      Hi every one , how can i achieve these as shown in pictures below with raytracer render  :
      Guys im really waiting for someone answering me please
