Mardie Posted August 28, 2018 Share Posted August 28, 2018 How do I get the second floor elevation markers off my first floor plan? second floor elevation markers.pdf Link to comment Share on other sites More sharing options...
Chopsaw Posted August 28, 2018 Share Posted August 28, 2018 You could Deselect "Display on All Floors" Link to comment Share on other sites More sharing options...
Mardie Posted August 28, 2018 Author Share Posted August 28, 2018 Didn't work, I deselected on all of the options for elevations. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 28, 2018 Share Posted August 28, 2018 For it to work in your current plan you must open and set all of the saved cameras. Previous example is so you can set it as default in your template plan so new cameras will follow those rules. Link to comment Share on other sites More sharing options...
Mardie Posted August 28, 2018 Author Share Posted August 28, 2018 Can you walk me through how to do that? Link to comment Share on other sites More sharing options...
Chopsaw Posted August 28, 2018 Share Posted August 28, 2018 You will need to open each of the affected cameras one at a time and while it is open use the use the Edit Active Camera tool to access the DBX that is formatted the same as it is for the camera defaults pictured above. Link to comment Share on other sites More sharing options...
Mardie Posted August 28, 2018 Author Share Posted August 28, 2018 Great! That worked - thank you! Link to comment Share on other sites More sharing options...
