SktrChief58 0 Posted August 23, 2018 I am new to CA, converting from Archicadd and am having problems with the Dimension Tool techniques even though Ive watched the videos numerous times I do not see answers to my questions. Please see the attached PDF which contains those questions. Thanks, Skeeter DIMENSIONQUESTIONS .pdf Share this post Link to post Share on other sites
Kbird1 822 Posted August 23, 2018 Eric is right PDF's are a PITA just use the Windows Snipping Tool (accessories) and attach the image Directly after saving it on your desktop 1.) the location of the Wall Dim is determined by the wall's main layer and which side is it's main side ( ie what is considered the exterior side) which is indicated by the square edit handle when the wall is selected at it's mid point. 2.) is an overall Dim ( note the arrows only on each end ) you can add dim location points by dragging off the diamond and placing it on the point you want located ...if there is a diamond to drag otherwise you could add a manual point to point dim too. check this video for the use of the diamond.... https://www.chiefarchitect.com/videos/watch/5432/editing-dimensions-and-extension-lines.html?playlist=92 3.) Line A is the same as the outer line to it's left it appears, typically CA will only give 3 lines off Dim. automatically line the other sides of the building so I am not sure if A is one you drew manually? if so it is properly just the wrong type , eg you used point to point instead of a Running or Baseline Dim. M. Share this post Link to post Share on other sites
