JECORMIER Posted August 21, 2018 Share Posted August 21, 2018 Hey All- I'm working in x8 (still, yeah I know) and I'm running into a situation where I've changed the wall color fill to black. When I place a dimension on the right side of the wall the dimension arrow can be seen just fine, but when I place the dimension arrow on the left side of the wall (arrow is within the wall area) I loose the arrow visibility. Where do I find the background color for the ends of the dimensions? My thought is that I'd turn the background to white. Note: I do realize I can simply make the fill of the arrowheads white and move on, but I'm trying to match a certain style and I would like to use black arrows w/ black fill AND black wall fill. Any suggestions would be great. Thank you Justin See attached screenshot Link to comment Share on other sites More sharing options...
Chopsaw Posted August 21, 2018 Share Posted August 21, 2018 Link to comment Share on other sites More sharing options...
JECORMIER Posted August 21, 2018 Author Share Posted August 21, 2018 Thanks Chop. Yeah, I noted that I could simply fill the arrows with white, but I was trying to get a certain look that would require both the dimension arrowheads and walls to be black. I figured there ought to be a way to give the dimension arrowheads a white background box behind them but maybe there isn't that option. Hmmm. Thanks again. J Link to comment Share on other sites More sharing options...
Chopsaw Posted August 21, 2018 Share Posted August 21, 2018 Sorry, not that I am aware of unless you wanted to layer something in manually. Link to comment Share on other sites More sharing options...
JECORMIER Posted August 21, 2018 Author Share Posted August 21, 2018 Ok. Thank you chop. Link to comment Share on other sites More sharing options...
