Specialty storage cabinet
pgjacob
Hi All
Trying to make a cabinet that looks like the image in attached pic.  I can find the metal part of this drawer in the library under one of the manufacturer catalogs.  But when I build the drawer, the side panels are there.  I just want the drawer front...
thanks in advance
melissa
5 hours ago, pgjacob said:
Attached results!
Glad you got it to work. The insert you used is for a tall cabinet so it has too many shelves. If I were going to the trouble to show that to a client I'd want to be a bit more accurate. The only wire frame with 3 shelves for a base cabinet that I know of comes from Hafele. Rev-A-Shelf only offers a two tray that is shorter. Plenty of wood solutions, just not wire ones.
I put one together and posted in the symbol section. You can also get baskets with wire bottoms but I didn't do that-if I wanted that I'd use a texture to replace the maple.
Maybe read up on symbol creation (and hacking -look for some posts by Alaskan Son)
