Custom Tile Pattern, staggered subway
wpdesigninc
Making the Pattern file is fairly easy , there is a free Excel .pat file generator at the link below I use , just be sure to save the .pat as the exact name in RED so they work . Best to keep them in Chief's Pattern Folder.
The Texture or Image of your 1/3rd offset is the hard part but you maybe able to find one online if you don't already have a seamless sample image? Otherwise you would need to make a single tile material and then use material regions , in rows, to get the Offset which could get tedious but Copy and paste would help to make multiple Material Regions, doable if the area you need to cover isn't too large.
http://www.cadhatch.com/hatch-pattern-generator/4588167700
