alaska Posted August 21, 2014 Share Posted August 21, 2014 Does anyone know of a way to draw diagonal siding to match a 5:12 roof pitch? Link to comment Share on other sites More sharing options...
KilgoreTrout Posted August 21, 2014 Share Posted August 21, 2014 Make a copy of the siding material with the texture and/or pattern rotated to the same angle. Apply the new material to the exterior wall surface. If you have a gable, you might need two materials with opposite angles and then split the wall using the break tool. Link to comment Share on other sites More sharing options...
rlackore Posted August 21, 2014 Share Posted August 21, 2014 Like this? Just rotate the pattern to the angular equivalent of the roof pitch, and do the same for the texture file (though in my experience the texture file might have to be rotated in the opposite direction, not sure why). Link to comment Share on other sites More sharing options...
