jenmarsch Posted June 25, 2018 Share Posted June 25, 2018 I'm trying to add more architectural detailing to the exterior of a Mediterranean style home. I have the columns and arches worked out, now I want to add moldings around the entryway and around some windows. I dont want to create a belly band around the whole thing. What is the best way to attack this decorative element? Please Link to comment Share on other sites More sharing options...
jenmarsch Posted June 25, 2018 Author Share Posted June 25, 2018 (edited) version x10, figured out the signature. an the first image is what I'm sorking on and the second image is close to what I'd like to achieve. Edited June 25, 2018 by jenmarsch added more detail Link to comment Share on other sites More sharing options...
joey_martin Posted June 26, 2018 Share Posted June 26, 2018 Look in the menu under BUILD and you will see some options for TRIM. You can take an elevation view and use the 3D molding poly line tool to create all the various moldings you are after. 1 Link to comment Share on other sites More sharing options...
jenmarsch Posted June 26, 2018 Author Share Posted June 26, 2018 On 6/26/2018 at 3:30 AM, joey_martin said: Look in the menu under BUILD and you will see some options for TRIM. You can take an elevation view and use the 3D molding poly line tool to create all the various moldings you are after. Expand Yeah!! thank you!! 3-D molding line is exactly what I needed!!! Thank you so much! I have a perpetually unhappy client and this will help Link to comment Share on other sites More sharing options...
joey_martin Posted June 27, 2018 Share Posted June 27, 2018 Glad I could help. Link to comment Share on other sites More sharing options...
