Exterior Molding Custom only on facad
jenmarsch
I'm trying to add more architectural detailing to the exterior of a Mediterranean style home. I have the columns and arches worked out, now I want to add moldings around the entryway and around some windows. I dont want to create a belly band around the whole thing. What is the best way to attack this decorative element? Please :)
version x10, figured out the signature. an the first image is what I'm sorking on and the second image is close to what I'd like to achieve.
Edited by jenmarsch
added more detail
6 hours ago, joey_martin said:
Look in the menu under BUILD and you will see some options for TRIM. You can take an elevation view and use the 3D molding poly line tool to create all the various moldings you are after.
Yeah!! thank you!! 3-D molding line is exactly what I needed!!! Thank you so much! I have a perpetually unhappy client and this will help
