ChiefuserMathews Posted June 22, 2018 Share Posted June 22, 2018 hello, how to copy objects in circular pattern? Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted June 23, 2018 Author Share Posted June 23, 2018 Thank you for your quick reply. I tried that. It doesnt allow me to select the centre point where i want it to get revolved Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 23, 2018 Share Posted June 23, 2018 Edit>Edit Behaviors>Rotate/Resize about current point. Then Place Point at your desired center location. You can then use a number of methods to proceed from there including not only Eric's suggestions but also Multiple Copy using the rotate handle. Link to comment Share on other sites More sharing options...
