chiefmodify Posted June 11, 2018 Share Posted June 11, 2018 Trying to build out the master with two dormers sitting in it and can't figure out a way to hide the dormer walls (without exploding dormer) Obviously, the walls aren't quite appropriate as you can tell from the inside camera view. Thanks for all the help!! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 11, 2018 Share Posted June 11, 2018 MOVE THE DORMER WALLS TO THE ATTIC FLOOR ABOVE, THEY WILL LOOK THE SAME IN CAMERA VIEWS AND BE GONE FROM THE LOWER FLOOR. 1 1 Link to comment Share on other sites More sharing options...
chiefmodify Posted June 11, 2018 Author Share Posted June 11, 2018 mmm. I never figured out how to do that either tried. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 11, 2018 Share Posted June 11, 2018 Select the dormer walls and just cut--paste hold to the next upper level. Link to comment Share on other sites More sharing options...
chiefmodify Posted June 12, 2018 Author Share Posted June 12, 2018 You are right, copy and pasting dormers as a whole to the attic worked!! Thanks Perry! Link to comment Share on other sites More sharing options...
TGMcKenna Posted September 7, 2023 Share Posted September 7, 2023 hmm - almost works for me, but I'm getting some weirdness still showing up. Help! Thanks, all. Tim Dormer.pdf Dormer 2.pdf Link to comment Share on other sites More sharing options...
