chiefmodify Posted June 7, 2018 Share Posted June 7, 2018 Not sure how to ask... Seems the black line extending from the drawing is top of the ground. To me the story pole should mark that as 0, and then minus numbers down, and add from above.... but as you see starts from below... How do I correct? Thanks, Link to comment Share on other sites More sharing options...
glennw Posted June 7, 2018 Share Posted June 7, 2018 Open the Auto Storey Pole Dimension Defaults. On the Locate Elevations panel set the Grade Level Marker to a negative number equal to the Subfloor Height Above Terrain - or the distance between your ground line and your floor 1 level (usually zero). In the picture below, this is set to -300mm. Set the Elevation Reference to Grade Level Marker. Generate the auto storey pole dimensions. Is this what you want? Link to comment Share on other sites More sharing options...
chiefmodify Posted June 7, 2018 Author Share Posted June 7, 2018 Sure is... Will give that a shot... Thanks so much Glen!! Link to comment Share on other sites More sharing options...
