JoyThedens Posted June 1, 2018 Share Posted June 1, 2018 HELMUTH PLAN.planHELMUTH PLAN.planHELMUTH PLAN.planHELMUTH PLAN.planI am new to Chief Architect (probably obvious) and I am having an issue with my garage front wall. The garage door will not "cut into" the concrete foundation wall and I cannot figure out how to fix it. Help??? Link to comment Share on other sites More sharing options...
Kbird1 Posted June 1, 2018 Share Posted June 1, 2018 Joy , your plan file is not attached...make sure it is not open in CA before trying to attach it as CA Locks the File while it is open. Also, it's good to have your Forum Signature filled in, especially with the Software Version, and of course a real Name is nice too ..............see mine below in Blue for how to do that. If you don't see my Signature then you have them turned off for the Forum so you need to Toggle it on in UserName>Account >Signatures...... go to the Upper RH Corner of Forum Window. M. 2 hours ago, JoyThedens said: HELMUTH PLAN.planHELMUTH PLAN.planHELMUTH PLAN.planHELMUTH PLAN.planI am new to Chief Architect (probably obvious) and I am having an issue with my garage front wall. The garage door will not "cut into" the concrete foundation wall and I cannot figure out how to fix it. Help??? Link to comment Share on other sites More sharing options...
JoyThedens Posted June 1, 2018 Author Share Posted June 1, 2018 ??? HELMUTH_PLAN.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted June 1, 2018 Share Posted June 1, 2018 Looks Like Eric is onto something , I just changed the Garage Front wall back to "Default Bottom height" and it fixed it *** in the OP looks like you tried attaching the plan 4 times? but because it was locked it didn't really attach , so it is a dead link when clicked on. Link to comment Share on other sites More sharing options...
JoyThedens Posted June 1, 2018 Author Share Posted June 1, 2018 Perfect!!!! You guys are amazing. Thank you! Link to comment Share on other sites More sharing options...
