Max on Added Lights
TKInteriors
Thanks in advance for any help....
I need to add LED lighting along the inside of ceiling coffers.
I tried recessed strip lighting but the gaps between the lights are two large.
I am inserting Added Lights but can't add anymore than you see in the plan view.
Any suggestions would be appreciated.
Kind regards, Tamela
Mark posted some LED strip lights in the Symbols Forum today , you can open the plan and save one of the horizontal ones to your Library and try it.
It is easy to adjust the number and spacing of the Light Sources on the Light Data Tab , you should be able to make a 8' section with a light every 6" for example and then copy paste it around the room.
The number of lights you can turn on may depend on your videocard and Cheif Version though....you still haven't filled in you signature so nobody will be sure.... see my Sig. for how to do yours....
