EconBlueprints Posted May 25, 2018 Share Posted May 25, 2018 I want to include certain information for my window and door schedules. The Default Window schedule has been modified to include fields for "Egress" and "Tempered Glass". I have also added fields for Clear Opening Width, Clear Opening Height, Net Clear Opening, Clear Glass Area, Net Ventilation Area. For any given window, under the "Object Information" area, I have assigned a value for each of the above. When I create the Window Schedule, all of the Fields show up, and all of the values are in each Field Category, but "Egress" and Tempered Glass" Field Categories have no values assigned. Anyone know how to fix the schedules and object information so all fields fill in? Thanks, Lane Link to comment Share on other sites More sharing options...
joey_martin Posted May 25, 2018 Share Posted May 25, 2018 Open the window(s) and make sure the box is checked for those items to be included. Chief will not make a window egress or tempered based on size, you must check the boxes. Link to comment Share on other sites More sharing options...
EconBlueprints Posted May 25, 2018 Author Share Posted May 25, 2018 Ok, I see Chief used some information from the Set Up area for each individual window. So checking the box will include the egress info. Got it, thanks. Lane Link to comment Share on other sites More sharing options...
