cv2702 Posted May 18, 2018 Share Posted May 18, 2018 I'm trying to create an above ground pool light. I started with a recessed spot,rotated it and set the correct light attributes. But it wants to be wall mounted. How can I change that setting to 'surface mount' which I assume would let me place it on the side of the core catalog rectangular pool? Or am I in the wrong direction and there's a simpler way to do this? Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 18, 2018 Share Posted May 18, 2018 Just use a symbol that you can locate where you need it to be and then use a "light source" for the light, which has its own dialog box to get the lighting effect you want. DJP Link to comment Share on other sites More sharing options...
cv2702 Posted May 19, 2018 Author Share Posted May 19, 2018 Thanks David, sounds like a good 'simpler' solution. UPDATE: Actually, just a light source (spot) will do it. Link to comment Share on other sites More sharing options...
