YellowfinDesign Posted August 14, 2014 Share Posted August 14, 2014 I have a plan open with the "Active Layer Set Control" set to Architectural Set. Therefore, I can see my wall layers (1/2" drywall on 2 x 4 studs). When I send it to layout, it automatically goes to "default set" and does not show the wall layers in the layout. I double click on the plan that is on the layout page to go back to the plan, and now the plan's "Active Layer Set Control" is now set to Default Set. How did this happen? I did not (knowingly) change anything. I have included a pdf of the layout as well as a pdf of from the plan view to show the difference. I can email the file if it helps. I would rather not attach the file to this post. Can anyone help me? Mike Ok quick update. This is only happening on ONE of the 14 pages in the layout file. There is another page that is linked to the same plan file, and that one works fine. 2014-08-14 Newman Bsmt Bar-Floor Plan.pdf 2014-08-14 Newman FM3-Layout.pdf Link to comment Share on other sites More sharing options...
Solution Joe_Carrick Posted August 14, 2014 Solution Share Posted August 14, 2014 So delete the offending Layout Box and then send the view to Layout again with the correct Layer Set. 1 Link to comment Share on other sites More sharing options...
YellowfinDesign Posted August 14, 2014 Author Share Posted August 14, 2014 WOW. I cannot believe it was that simple. Problem Solved!!!! Thank You!!!!!!!!!!!!!!!!!!!! Mike Link to comment Share on other sites More sharing options...
