Infratech SL-16 quartz-tube infrared heater
rlackore
This is a facsimile of the Infratech slimline series SL-16. There are three versions: ceiling mount, wall mount at 30 degrees, and wall mount at 45 degrees. You can stretch their length to simulate the SL-24 (42.5"), SL-30 (63.5"), and SL-40 (63.5") - the only thing that won't be "correct" will be the spacing of the face grill.
infratech sl-16.calibz
infratech.thumb.PNG.eb565c5f4533ac638fb750295592c1f4.PNGwallmount45d.thumb.PNG.213db780082d9572ce7d275c1c2e2472.PNGwallmount30d.thumb.PNG.93443c29756b02ad173260baadf712b1.PNGceilingmount.thumb.PNG.4863d4e44be9bb9c182823ff9102de0b.PNG
I discovered there are some really stringent mounting clearances for these products - so if you use them do your research (but avoid calling Infratech support - they aren't very friendly).
