Michael_Gia Posted May 6, 2018 Share Posted May 6, 2018 Plan is attached. I placed 3 spots in the soffit above the 3 garage doors. Chief placed them originally under the plywood of the sloped roof. I had to then adjust the height of the spots and angle to get them to sit flush to the soffit. What am I missing? Why doesn’t Chief automatically place them where a soffit/eave spot should be? Plan: https://www.dropbox.com/s/m6qmbb6apn7ur98/Joseph and Johanne test plan.plan?dl=0 Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 6, 2018 Author Share Posted May 6, 2018 So the solution is to draw a small ceiling plane outside where the eave is and then place your spots on it? Great fix but I was hoping there was some setting in roofs or wherever to allow a quite common item such as soffit lighting to behave as expected. Thanks for the suggestion though, it is a lot easier than fiddling with the light height and angle. Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 6, 2018 Author Share Posted May 6, 2018 Ok alternate solution is: -Open symbol (icon with chair and pencil - bottom toolbar) - Options tab, chose “floor mounted” - 3D tab, “Z Position” = finished ceiling height less an inch. (In my case Z = 173.5”) You can also chose “ceiling mounted” but uncheck “flush mounted” and then enter your ceiling thickness plus an inch for “Z Position” (in my case Z = -7) Link to comment Share on other sites More sharing options...
cv2702 Posted May 7, 2018 Share Posted May 7, 2018 21 hours ago, Michael_Gia said: Ok alternate solution is ... You can also chose “ceiling mounted” but uncheck “flush mounted” and then enter your ceiling thickness plus an inch for “Z Position” (in my case Z = -7) I use this approach, but here's a twist. When I initially place the recessed in the soffit, with no flush mount, they end up buried somewhere in the eave, so I add an offset from ceiling (10"). All is good and I save the plan. I later open that plan only to see the recessed hanging in the air, 10" under the soffit. So I change the offset to ½" and after that all seems well. I have seen this behavior on various plans. Drives me nuts. Anyone else? Link to comment Share on other sites More sharing options...
