country Posted April 12, 2018 Share Posted April 12, 2018 This is a design job I am currently working on. I am attempting to show shingle siding in some of the gable ends. I have changed the wall type on the upper front gable and garage gable, turned off auto attic walls but it is remaining siding to match the existing walls below. I'm sure I have done it this way before but maybe not. I will now turn Chief off and restart. I thought I would ask here before sending to tech support in case it is something obvious. Tech support takes a while (or more) to get back and I would really like to keep working on this exterior so I can get it off to clients. I could use the material painter but that is a last ditch option that I shouldn't have to use. AtticWalls041218..zip Link to comment Share on other sites More sharing options...
country Posted April 12, 2018 Author Share Posted April 12, 2018 Is this something I will have to do all the time in X10? It was never required before. If you changed the wall type and it had a different siding material, it changed. I have had this happen on a couple X10 jobs and thought it was because I brought them in from X9 (tech support thought this too) but this one was started in X10 with a brand new template. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 12, 2018 Share Posted April 12, 2018 Your problem is in your Exterior Wall Defaults. Your Exterior Wall Surface is not set to use the Default material. Fix that, and you should be back in business. Link to comment Share on other sites More sharing options...
country Posted April 13, 2018 Author Share Posted April 13, 2018 Thanks Michael. I will give that a try in the morning. Obviously, something I must have done wrong when setting up the template plan. I'm surprised Tech Support didn't notice that. Eric. I never "paint" anything unless I am doing some interior work after the construction drawings are complete or I use a seperate, save as, plan. Link to comment Share on other sites More sharing options...
