Attic Walls
Member Statistics
Similar Content
By LeeDrafter
Hello,
I would like to use a metal siding similar to this picture, and I can't find a similar material in CA. The closest I see is vertical paneling. I can adjust the angle so it's horizontal and change the scale for wider boards, but I don't know how to get rid of the wood grain look and change it to a metal texture. Any advice on a material texture that would work well?
Also, does anybody know what this type of large scale horizontal metal siding is called? Perhaps there is more information on Chief Talk already, but I didn't know what to search for since I don't know the technical name for this material. Thanks so much!
Lee
X12
By TonytheArcht
I've searched over all materials in the library and in bonus libraries unable to find a wall material that alternates between skinny and wide planks. The closest material I can find is the "Board and Batten" siding which has fixed skinny battens and wide boards. I know about sizing the image but what I'd really like to find is a material that I can control for both plank sizes--say, 4" & 8", or 3" & 6", or 2" & 7", etc. Anyone have suggestions? Thanks, Tony.
Chief Premiere X13, Dell computer, 64-bit OS, 11th Gen, Core i9, Windows Pro 11.
By Travis-Garcia
I cannot seem to figure out how to make this exposed gable have the same shiplap siding on it that the house has. I built the patio piece by piece using framing members and added roof planes and ceiling planes then added the gable. Now II cannot figure out how to add siding.
I'm using Home Designer Pro 2021
By AJ_Wrangler
having a difficult time getting the clear story wall done. tried quite a few different ideas but none really worked well. i drew in an attic wall but when i try to extend it forward it screws up the walls below.
Anyone know how to do it correctly? i have uploaded a few pics of the area and my plan file.
thanks andy
LL V5 floor framed v2.plan
By Randall30
I want to put vertical weathered lap siding on a house exterior but I do not see this in the materials listing, there is only horizontal weathered lap siding as shown in attached image. Is there a way to make it vertical??? Ultimately I am trying to go for a look like with the Juvet Landscape Hotel siding (photo attached). Can anybody help me? (I am using Chief Architect Home Designer Suite 2016 and if I can get this to work I will likely upgrade to the Architect version.). If needed I am even willing to purchase a separate materials library if it would accomplish this. Or do I need to create my own material?
