SNestor Posted April 3, 2018 Share Posted April 3, 2018 Is there a way to have the section line style be "dashed"...but the callout circle to be a solid line. The attached picture shows what I'd like to achieve... Can this be done thru some sort of setup...or will I have to use a cad line to connect to the callout? Link to comment Share on other sites More sharing options...
kMoquin Posted April 3, 2018 Share Posted April 3, 2018 Line type is an option on the plan display tab of the cross section dialog box. 1 Link to comment Share on other sites More sharing options...
SNestor Posted April 3, 2018 Author Share Posted April 3, 2018 1 hour ago, kMoquin said: Line type is an option on the plan display tab of the cross section dialog box. Thanks...that was easy. I had checked the box for "By Layer"...and when you change the line type in the layer...it changes not only the line but the circle for the callout also. Link to comment Share on other sites More sharing options...
