gobuildone Posted March 23, 2018 Share Posted March 23, 2018 I'm Running Chief X8, MS Windows 10 on SurfacePro3. Building three stories over a basement. Trying to create the Elevator Shaft. Elevator Shaft... 4 framed walls each floor to create a shaft for the elevator. Walls are Aligned with walls below. I have stair ways where Open Below rooms eliminate the Floor and Framing like they should. I have an atrium on floor 2 overlooking to floor 1, created with a railing and room Open Below... this works too (no floor). But on each floor where I box in the Elevator Shaft with 4 walls, create the room, designate it as "Open Below" there is still framing and decking inside the Elevator Shaft. I have "Rebuilt floors and Ceilings" and "Rebuilt Framing" does nothing. I have turned on and off Auto Framing. Deleted and Recreated walls Created the Shaft bottom floor first... and top floor first. One thing I have noticed is that this plan has created a Center Line running front to back in the plan and the front wall of the elevator shaft is sometimes split when I draw it. Any Ideas on how to get rid of the floor inside the Elevator Shaft? Thanks, TP Existing bldg plan 7.plan Link to comment Share on other sites More sharing options...
gobuildone Posted March 24, 2018 Author Share Posted March 24, 2018 Thanks for the info. I appreciate your help. I don't fully understand why my floors need to all be the default height to make this work. I'm detailing an existing building and the ceilings are not the same height. Once I build them with the default settings, can I edit the floors to enter the correct dimensions? thx, TP Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 24, 2018 Share Posted March 24, 2018 Your problem is that you changed your Room Divider default to No Room Definition. Not sure why you did that as the whole point of the Room Divider is to define rooms. At any rate, the connecting wall for your island room needs to have that setting unchecked and then you should be good to go. Link to comment Share on other sites More sharing options...
gobuildone Posted March 24, 2018 Author Share Posted March 24, 2018 Now we're on to something! Thank you both. I changed the room divider default because every time I tried to create the front wall of the elevator shaft the program made it two (half length) walls and I could not place a door in it. ...solved the door problem and created another. I could not figure out why the room dividing line was there to begin with as I've not seen it (or noticed it ) before. I don't mind seeing it, but it was jacking the placements in the plan. I appreciate your help. Thx, TP Link to comment Share on other sites More sharing options...
