Lighthouse Posted March 17, 2018 Share Posted March 17, 2018 I tried to create a new tile by: choosing an existing 10x10 tile in "plan materials" saving a copy renamed 12x24 changing the size to 12x24 (the size shows correctly in the dbx pattern window) adding to library then I open room and change floor material to 12x24 tile still shows up as 10x10 in camera views what did I miss? thanks! Link to comment Share on other sites More sharing options...
Lighthouse Posted March 17, 2018 Author Share Posted March 17, 2018 thanks, that worked Link to comment Share on other sites More sharing options...
glennw Posted March 17, 2018 Share Posted March 17, 2018 18 minutes ago, solver said: You need to change the texture. Typically done in something like Photoshop. Eric, Why use Photoshop? The texture size can be easily changed on the Texture tab of the material definition dbx. Link to comment Share on other sites More sharing options...
