KirkClemons Posted March 22, 2018 Share Posted March 22, 2018 6 hours ago, Kbird1 said: might have the setting too low currently at default for VFW Also, now that you have a better codec, I would recommend setting the Compression in the Walkthrough settings to 0%. You don't want Chief to compress the frames before passing them on to the codec to be compressed again. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted March 22, 2018 Share Posted March 22, 2018 5 hours ago, KirkClemons said: Also, now that you have a better codec, I would recommend setting the Compression in the Walkthrough settings to 0%. You don't want Chief to compress the frames before passing them on to the codec to be compressed again. Thanks , another great tip ! could you post your VFW Config please --screen shot perhaps ? Link to comment Share on other sites More sharing options...
