CBRF23 Posted March 10, 2018 Share Posted March 10, 2018 I'm trying to generate attic trusses over a garage and they are missing the bottom chords. The two end trusses seem to display correctly, but all the field trusses are missing the bottom chord. The field trusses were generated by copying the end trusses using the place copies at intervals while dragging tool. The non-attic trusses over the second garage generated just fine, so I'm not sure what I did wrong here. Bottom Chords.zip Link to comment Share on other sites More sharing options...
CBRF23 Posted March 10, 2018 Author Share Posted March 10, 2018 Eric, thanks again for your help, the attic wall trick looks to be what I need. Where did you find that info? I created these following the steps outlined in the help file here: https://www.chiefarchitect.com/support/article/KB-00981/creating-roof-trusses.html Any ceiling joists present were generated by the "build attic truss" command, as I just drew a truss using that command per the KB article and then placed additionals using the interval copy tool. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 10, 2018 Share Posted March 10, 2018 These may help Attic Trusses https://www.chiefarchitect.com/support/article/KB-00933/creating-an-attic-truss.html https://www.chiefarchitect.com/videos/watch/354/framing-with-attic-trusses.html Link to comment Share on other sites More sharing options...
