Bob-Roraback Posted February 25, 2018 Share Posted February 25, 2018 (edited) In the attached example I am attempting to connect a stairway to a second floor that has a railing overlooking the first floor and get the railings to line up. If you look at the stair railing I can't line it up with the upstairs railing. I have set the newell offset in the stair settings but railing does not follow the newel offset I am having trouble understanding what good the newell offset does if the railing does not follow. I have a door under the stairway which will have a stairway to the basement so making the stairway narrower would not work. How would you handle this? Thanks for any suggestions, Bob Railing problem.zip Edited February 25, 2018 by builder Link to comment Share on other sites More sharing options...
Bob-Roraback Posted February 25, 2018 Author Share Posted February 25, 2018 Thank you Eric. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 25, 2018 Share Posted February 25, 2018 16 hours ago, builder said: In the attached example I am attempting to connect a stairway to a second floor that has a railing overlooking the first floor and get the railings to line up. If you look at the stair railing I can't line it up with the upstairs railing. I have set the newell offset in the stair settings but railing does not follow the newel offset I am having trouble understanding what good the newell offset does if the railing does not follow. I have a door under the stairway which will have a stairway to the basement so making the stairway narrower would not work. How would you handle this? Thanks for any suggestions, Bob Railing problem.zip You Zipped your Plan while it was Open in Chief , so the Plan file is 0kb as Chief Locks the File while it is Open. Re Zip and repost if needed... M. Link to comment Share on other sites More sharing options...
