brian-sdesign Posted February 8, 2018 Share Posted February 8, 2018 Is this possible? I am pretty sure I have asked this same question in the past and there was a way, but I have forgotten and no luck using a search so far. To clarify I would like to be able to change multiple rooms at once instead of having to open each rooms strucutre dbx one at a time. When I select multiple rooms, the heights in the strucutre dbx are greyed out. I'm not looking to do the entire level because I have some areas that are correct. Anyway please let me know what the options are. Thanks a bunch! Link to comment Share on other sites More sharing options...
Kbird1 Posted February 8, 2018 Share Posted February 8, 2018 So the Match Properties Tool (Multi Select) does not work ? 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted February 8, 2018 Share Posted February 8, 2018 On 2/8/2018 at 7:51 PM, solver said: It's dumb that you cannot simply select multiple rooms and make a change. Expand No Quibble there , at least we have the Match Tool now... Link to comment Share on other sites More sharing options...
brian-sdesign Posted February 9, 2018 Author Share Posted February 9, 2018 Did not know about the match tool. Thanks for the tip! Link to comment Share on other sites More sharing options...
