Library catalog downloads are opening in wrong version
Draftsmith
I am using X9 and when I log in to download a new library catalog even when i select an item that's only available in X9 or X10 after it download and i click to open it my computer opens up X8 version and the catalog is only available in X8 and not X9. What am I doing wrong?
It sounds like X8 is still the Default "Handler" for .calibz Files , you can go to
Settings>Apps>Default Apps> Scroll to bottom >choose Defaults Apps by File Type>
scroll down and find .calibz > Click on the Program name (X8?) and choose X9 or X10 > Ok/Close Settings....
it doesn't normally need a Reboot by may ...
  • 8 months later...
Mick,
I am having this same issue. When I go through your steps, X10 does not show up. Any ideas?
Thank you,
3 hours ago, Anna_Gorres said:
Got it - thank you!
Did the 2nd method from the command Line Work?  ( it apparently doesn't anymore with Win10 1803 (April Update), I have updated the Other thread linked above with other methods too but the easiest is ......
Right Click a .calibz file and Choose Open With>CA X10  (scroll Down to bottom if you don't see X10 listed and choose look on PC and once found look for the Checkbox that says Always Use this App
