3d editing lag in X10
Oakriverman
Is anyone else having lag when editing in 3D?  I just installed the X10 Beta today and am working through the settings.  I have adjusted everything in preferences that I know of to no avail...
To move a window 3 inches in standard ortho view is taking between 5 and 10 sec.  X9 on the same machine(specs below) is 1 to 2 sec.  Hardware edge smoothing setting doesn't seem to have an effect on this delay.  Everything is optimized for multi-cores.
I will say though that I am pleased with the speed at which the camera moves around after the scene is rendered.  I would just like to shave a few seconds off when editing in 3D.
Thanks!
Update: Fixed!
Went through and prioritized my pc for X10 and it helped a bit.  However, I realized that the model I was working in was originated about 3 versions back.  I brought up a model created in X9 and it worked like a charm!
there are a few issues with old plans brought forward I have found so far....
- the new Header Labels don't show properly if the framing isn't rebuilt
- Component lists don't update their description fields if changed to show in the New materials list...
